Does current electric code mandate an installation of a light fixture in every bedroom's closet?
What country/state/etc.? (Codes vary around the world). I suspect the answer is dependent on the size of the closet - a 2' x 4' closet is very different from a 6' x 8' walk-in closet.– manassehkatz-Moving 2 CodidactCommented May 23, 2019 at 23:17
1California, 2' x 4' closet, residential.– H1991Commented May 23, 2019 at 23:29
I think it is. But way back when,If closet was 3x3 or larger you put in light over door. Kept Ahj happy and did not have to worry about shelf , clearances.– user101687Commented May 23, 2019 at 23:31
Ya 2x4 was funny If room had a light boss didnt add closet light, If it only had switched outlets for lights he would put in a closet light .– user101687Commented May 23, 2019 at 23:38
The answer is yes .Not sure what your asking. there are rules on ,what type of light to were it can be installed in the closet'– user101687Commented May 23, 2019 at 23:45
Add a comment
