**enter image description here** Electrical box wire at 12 position is hot. That bundle has black white and ground. I Want to install light fixture with two wires...what is proper connections. I assume wire bundle at 3 o’clock is from switch red white black and ground...but just not sure how the connections should go Thanks for any help
    Aside from ground, which two were the old fixture attached to? Dec 18, 2017 at 18:19
  • That red wire should be assumed to be hot or switched based on its color and should also be capped off. Don't leave it exposed.
    – JPhi1618
    Dec 18, 2017 at 18:40
    do a continuity check between "3 o clock" red-black as you operate the switch. Obviously be absolutely certain the power is off first.
    – agentp
    Dec 18, 2017 at 18:51
Wire nut two blacks together. Push them back in the box. Attach new fixture black to red. Connect all whites together. Connect all grounds together.
