I'm interested in installing LED strip lighting around a door frame in a reach-in closet and laundry space (essentially a deeper reach-in closet with washer/dryer side by side).
I plan to purchase aluminum channels, install them along the sides and top of the door frame, next to the molding, and insert the LED strip lights inside. I would like to also have the lighting be controlled by a regular light switch or sensor.
I am having difficulty deciding if going with a regular plug-in transformer or with a hardwired transformer option is best (i.e., looks professional)/code-compliant.
I'm not sure that I want an AC adapter brick hanging out on the floor or shelf (or wherever I decide to put it). Similarly, if going with the hardwired option, do I need to enclose it in a box or protect it somehow?
Thanks!
