We started a remodel of our bathroom. It is a 1949 built house, one level with partially finished basement. After we did the demo, we got concerned about entering the attic to do any venting. It is an older home with vermiculite insulation. It is a small bathroom with one outside wall where the shower/bathtub combo covers that entire wall. Is there a way to vent out the wall or down through the basement and out that wall so we can avoid the attic? The basement directly below is unfinished.
2There's no reason you can't vent through the wall other than the hassle of warm, moist air and odor at a lower exhaust location. If that's acceptable, you're golden. I wouldn't shy away from working in your attic, though. I owned a 1950s home for many years and did a number of projects up there. Protect your lungs with a simple dust mask and it's not an issue. – isherwood Aug 1 '16 at 19:27
isherwood is right -- a properly fitting dust mask (especially in the diy context, where you're not exposed on a regular basis) is perfectly adequate. If you want to overdo it, get a tyvek suit and shower after you've been up in the attic. – Aloysius Defenestrate Aug 2 '16 at 2:28
There are wall mounted bathroom vent fans like this. I don't think going down through the basement would work as well as the wall unit.
No matter what you end up doing install a push-button timer to control the fan rather than a switch. You can reduce almost all mildew / mold concerns if you leave a fan running for 30 minutes after a shower.
