I needed to replace the old with the new one. http://www.bunnings.com.au/estilo-chrome-washing-machine-set_p5003030
My problem is that I didn't manage to screw it exactly tight for the connectors to a washing machine to be positioned strictly vertically down. So cold water connector looks rather up, hot down to the side. I must have done something wrong, but it seems too much tension is required to reach vertical down position. I should clarify that I screw the whole tap without disassembling on its parts.
