I've connected up washing machines before but this time I'm confused. I have two lengths of pipe attached to the washing machine, one which is the input water pipe, and one which is the waste/output pipe.
On the wall the pipe at the top on the right has a washer covering the end and is ultimately connected to the cold tap on the sink, I'm guessing that's where the input water comes from, but I can't see a tap connected to it (without removing the panel under the sink) and the sink adjacent works now. I'm concerned if I remove that water pressure will cover me with water! My only other thought would be the white tap under the sink?
Equally the one on the left is open so I'm guessing that's water coming out of the washing machine. Is that right?
