I'm trying to assemble a glider patio chair which I ordered. The main pieces (seat, back, sides, etc) are assembled and I'm supposed to just screw the pieces together. How are you supposed to tighten these things? There's nowhere to use a screwdriver to hold it in place when tightening the nuts. The holes aren't big enough for the bolts to go in flush, and they're tight enough that I'm having to screw the bolts to get them to go all the way in. Last time I used carriage bolts on something I built myself, I think the holes were loose enough that I could just push the bolts through and then tighten them with nuts. I don't remember how I held the bolts in place while tightening them on that last project.
Am I supposed to re-drill the holes bigger so I can just slip the bolts in flush?
There is is a good picture of a carriage bolt here.
