I tried to install a dimmer today in the dining area and found my switch is very over complicated. The switch only controls one ceiling light but has nine wires inside.
The 3 white wires are all just connected to each other. Same with the 3 ground wires. Two black wires currently connect to the bottom of the switch and one to the top.
Can I install a dimmer here and how?
