I'm trying to install a dimmer switch on a 3-way switch (there's another switch that also controls this light). The old switch has a black and white wire each connected to a brass screw, another black wire going into a hole labeled common, and a third black wire attached to the black screw next to the common hole. The bare ground wire is coiled up in the back of the box. The directions only mention connecting 4 wires, including the ground. We initially got the light to work and dim when connecting the third black wire to the ground on the new switch. However, another light and ceiling fan didn't work. I suspect one of the black wires goes on to power the other light switch and fan downstream. Where do I attach this wire to the dimmer?enter image description here
    I'm usually one to be encouraging, but you should probably stop doing electrical work until you do some basic study of wiring principles. You're flirting with disaster. Connecting an unknown wire to ground is never a good idea.
    Aug 17, 2020 at 21:23
    By the way, the wire on the black screw is stripped too long and wound backward on the screw.
    Aug 17, 2020 at 21:26
  • Hello, and welcome to Home Improvement. Here, trial and error can start a fire, or kill you or a loved one. And, you should probably take our tour so you'll know you'll know the details of contributing here. Aug 17, 2020 at 22:43
You'll have to take the black wire that was hooked to the black common screw and hook it to the black wire that went into the hole marked "common". Then both of those wires get connected to the "line or hot" wire for the dimmer. The other two wires get hooked to the dimmer per the instructions as does your ground wire.
