The drain tubes for the Furnace and AC run about 10 feet across the laundry room to the drain in the middle of the floor. Unfortunately this is a fairly high-traffic zone (seven people living in the house) and it is a bit of a tripping hazard. Does anyone have suggestions for different lines or something I could put around the line to avoid tripping?
  • what size, and material are the tubes? – Tester101 Jul 3 '14 at 19:32
  • One is 1/2" pvc, but the external diameter is closer to 3/4". The other is a clear flexible tube that's about 5/8" external diameter. – Anthony F Jul 3 '14 at 21:43
I'm imagining it's only a 1/2" pipe, in which case maybe an on-floor cord protector might work: http://www.homedepot.com/p/Legrand-Wiremold-5-ft-Over-Floor-Cord-Protector-CDBK-5/100669770
Or you could re-route the pipe around the perimeter of the room to avoid the heaviest traffic.
Another solution -- the one used in my house for both the condensing furnace and the dehumidifier -- is to run the drains into a small condensate pump. The output tube from this pump can then be routed up to ceiling level, across the room, and then down into the drain.
  • This is the best way to achieve what your looking for. You can have it pump to any laundry tub using a condensate pump. As long as you can live with the small noise of it turning on and off for a few seconds every time it needs to discharge. – Mnc123 Aug 2 '14 at 6:14
