I have a rental unit and I can not find a condensation drain line on the home heating unit. The unit is old and my question is do all heating units have a condensation drain? Thank you
1 Answer
A furnace only has a drain if it's a high efficiency condensing unit, or it contains an A/C evaporator coil.
If it's an older non-high efficiency unit, and there's no integrated air conditioning. Then it probably won't have any type of drain.
