I recently bought a house with the laundry closet upstairs. The washer and dryer were conveyed to us by the sellers. The washer does not have a drain pan underneath it, and as far as I can see, the laundry room does not have a floor drain.
I'm planning to have a drain pan placed under the washer, but I don't think I will install a floor drain as this will require substantial plumbing work (the laundry closet is in the middle of the house).
What else can I do to prevent water damage from supply hose leaks in the absence of a floor drain? I'm thinking of installing the Floodstop automatic shut-off valves, and wondering if anyone has experience with this or better suggestions.
A product like Floodstop will not prevent leakages from the drain hose. Do I need to be concerned about significant water damage from a detached/leaking drain hose? The washer I have is an LG Direct Drive front load one, so it minimizes the water it holds at any point in a cycle. If I do need to be concerned about drain hose leakage, what solutions are available to prevent it?
Thank you, Fijoy
