The handle on my SubZero refrigerator just came off. The "thing" that's attached to the door is fairly stiff and I haven't been able to unscrew it yet. Inside the hole in the "shim" that attaches to the handle is a star screw that holds the shim to the handle. Any idea how I would reattach this handle to the fridge?
Including the model number will get you the most accurate answer. – Tester101 May 29 '14 at 21:32
There should be a small set screw on the inside of the handle (opposite side of the picture). This is usually driven with a small Allen key. Loosen the screw, place the handle back on flush against the door surface, and tighten the screw finger-tight. Don't over tighten as they strip easily because they are so small.
The screw will look something like this
(source: funrcboats.com)
There might be a small plastic cap over the set screw in order to better hide it.
Turned out that the set screw was under the shim - in case anyone else comes across this answer and needs to find it. – Guy May 29 '14 at 22:08
What size is this set screw, need to find the right Allen for it. – user23740 Jul 13 '14 at 12:30
A 3/32 allen wrench worked on my box. It's a 2006 – user31878 Jan 20 '15 at 0:53
A 3/32 Allen wrench worked for mine as well, with a #10 - 32 x 1/4 inch socket screw – user56647 Jul 20 '16 at 23:23
