I need help in fixing my Samsung fridges door lever. Without it, the fridge door doesn't close tight enough leading to condensation inside the fridge.
This is a french door fridge. This video shows the lever replacement so that you get an idea how the lever looks like (https://youtu.be/mGnHxMNtrLQ).
The screw that attaches the lever goes into a plastic screw bracket. In my case, unfortunately the whole screw bracket has broken off.
This is the other door with intact lever - the screw can be seen here whose bracket has broken off.
What can I do to attach the door lever? One radical way could be to drill the screw into the door but that sounds like a recipe for disaster.
