I'm designing the kitchen (renovating a 100+ year old house) and I would really really like to make it a "G layout" kitchen (like a U shape but with breakfast bar peninsula) but in order to achieve this the fridge would need to be INSIDE the wall with the door flush with the wall! The back wall is already filled with cabinets and the sink so that is why I wouldn't want to put the fridge there. See my 3d model I made with ikea.com:
My question is:
What could go wrong? I'm basically just doing a sanity check and making sure this isn't a terrible idea. (I'm having a hard time googling this as this is not a common thing to do I guess)
Alright in order for you guys to answer the question you'll need much more info. Here's what I can tell you:
- The room that the fridge will go into is the laundry room. There is nothing in the way! It's an ugly, utilitarian room and we don't care if the back of the fridge is facing the washing machine) though boxing in the fidge would be nice).
- The laundry room in which the fridge will go into is a bump-out extension of the house.
- When they added the extension, it's like they left the exterior of the house exactly as it was and made that the interior of the new laundry room. The old asbestos shingles are still there on the wall, the soffit from the old roof is right where it always has been, and there is a big window right where the fridge will go! In fact it is almost tall and wide enough to fit the fridge in it, but it's a few inches too far to the right.
- the floors between laundry room and kitchen are not on the same level. And the corner of the floor (concrete) on the kitchen where the fridge will be nearest, there is an obvious rise in height making a concave shape in the floor. (I mean, its maybe an inch total, like you wouldn't notice it but it could screw with stuff).
- the wall is a load bearing wall. However I don't think there'll be any problems installing a header or just moving the window header up a little bit.
- the ceiling in the kitchen is low! 7 feet to be exact.
- the electrical circuit breaker is in the laundry room. Thankfully its a couple inches to the right of the fridge so that won't be a problem however there may be wires running bellow the window frame but I suspect that there is not.
- the door to the laundry room will be to the right of the fridge, as shown in the 3d model.
- the whole kitchen is 11 feet wide and 21 feet long but we intent to use much of that space for a dining area. The other kitchen layout option we are considering is making it an L shaped kitchen by loosing the breakfast bar and puting the fridge there (to the right of the window) but we don't like that layout as much. Too open.
So, is this doable? How would YOU tackle this project? Are there any restrictions or code requirements? Would it be just like a cased opening? Thanks!
