My EV car charger / EVSE is a Emporia Classic 48A Smart charger, installed on an exterior wall at the driveway. The J1772 cable is 24 feet long and will drag along the concrete driveway + bushes + grass next to the driveway. I'd like protect the cable from abrasion and wildlife: our neighborhood has rodents, turtles, raccoons, opossum.
I asked Emporia for their recommendation; their reply, emphasis mine:
To protect the cable from the unwanted rodents we could go ahead and use a metal braided sheath! This metal should have no issues with the temperature during the hot summer days.
Metal makes sense for heat dissipation. Unfortunately, metal braided sheath means detaching the J1772 cable because virtually all available sheaths' are too narrow for the large J1772 plug. The braided sheaths appear tricky to slit open and then close up again reliably.
Is this alternative idea below safe?
Wrap the cable with 3M Heavy Duty Aluminum Foil Tape 438. It is an outdoor-rated, thermally conductive, and heat reflecting.
Then, around that, install this Electriduct Stainless Steel Spring Guard Hose Protector. It is also weatherproof.
My concerns: any electromagnetic risk by having all these metal things wrapped around a 240V @ 48A / 11kW electric cable? I'll also have wrought iron hose guides to keep the cable off the ground wherever possible.
// my current research
- I've asked Emporia, but have not heard back for 3 days now.
- This DC fast charger appears to uses a metal coil for strain relief. See the far left charger.
