Hoping to get some help with my recent thermostat installation. I live in a house built in the 70's and the wiring is not straightforward for a layman. Upon installing two new baseboard heaters and thermostats, I was greeted by a burning plastic smell a few minutes after turning the breaker on and what I think was a flash (I was concentrated on something so not sure if the flash was my lights or just being tired). Naturally I turned off the breaker immediately and went to investigate. I didn't find any burnt wire nuts or components in either the heaters or the thermostats. The smell is also not a strong one either, and dissipated within 30 minutes or so.
Can someone look at my wiring diagram and tell me if I did something wrong? I emulated the wiring configuration from the previous knob thermostats, but maybe I'm missing something?
EDIT 1: Adding details that are important given comments received, namely that there is a third thermostat and heater coming from the bathroom on this circuit (this one has not been changed and is the original heater + tstat) and that the wire gauge running from the heater to the tstats are all 14-2 with all other connections being 12/2.
