I don't know if this is a dual pole or single pole thermostat (n00b here, don't know what I'm talking about). I don't even know what voltage this is (240 or 120).
But here's a photo of the wiring:
I bought a wifi Honeywell which includes a number of different wire connections in the back (says, "will not operate without the wire C connected"):
1) Will this work, or do I need a different thermostat for a baseboard heater?
2) I see three wires connected to the old, knob-driven thermostat: red, black, and white. BTW, the old thermostat says Load is black and Line is red. Which wires do I connect to which terminals on the new wifi thermostat?
FYI, I did turn off the power at the breaker. That switch connects to 3 thermostats+baseboard heaters in total. The thermostat I'm working on is only connected to one heater.
Get a different 'stat
The thermostat you have is designed for low voltage (24VAC) systems such as gas furnaces and heat pumps. You'll need a line voltage thermostat instead (and yes, wifi line voltage 'stats are a thing.)
