Replaced a ceiling fan thinking the motor was faulty, however the new one is not turning on.
I wired the fan following the instructions below without luck. I’m using wago connectors to connect the wires.
I also noticed an additional wire coming from the ceiling without covering or color which I connected to the blue wire to see if that worked but no luck. I am hoping I did not damage the fan but besides this, what else could be the reasons for the fan not functioning?
The wiring is per the instructions. Black and blue to black, white to white, green to ground screw. There is also a bare wire which I covered with a wire cap. I will be checking voltage of each wire once the tester comes in.
The switch has red yellow and black wires connected which correspond with the wall light outside but I don’t see any white wires connected which the ceiling fan does have. Could this be the cause of the problem?
I am also in the process of installing a ring can to the wall light outside which uses the same outlet. Pics of the wiring provided. I would like the switch to work both with the ceiling fan and the wall light outside. The ceiling fan would use the right switch and wall light left switch.
