I am replacing a ceiling fan (old fan had wall switches (1) for light (1) for fan). The new fan also has a light but has a wireless remote too. My issue is that the old fan used, black, white, blue, & green wires. The new fan motor only uses black & white wires.
So I can not use the wall light switch and fan wall switch to control the fan I have to use the remote. I want to use the wall switch to turn fan on/off and the fan switch to turn the fan on/off.
Can I somehow use my wall switches to my new fan. The box to the fan has all the wires the fan doesn't. Can I add a blue wire to the light fixture thru the fan? Install instructions: http://pdf.lowes.com/installationguides/836071007989_install.pdf
