The previous owner of my house spliced the downstairs lighting circuit to power some outdoor heaters. They ran the twin and earth cable through the exterior wall, and wired it into an external switch to control the heaters. It was a terrible mess, I didn't trust it at all, and I didn't want the heaters anyway. So I've decommissioned the whole lot, and have temporarily spliced the lighting circuit back together inside a weatherproof junction box.
I'm now thinking I'd like to make use of this point to add a security light, but I want to do it properly.
What I have is a loop of cable coming out of the wall, about a metre long. (50cm up to the junction box, and back down again). My feeling is to replace the junction box with a fused connection unit (like this one). The security light doesn't really need a switch as it has a sensor, but I figured this was preferable to just wiring the security light into the junction box, and I wasn't sure exactly how to wire it in either.
If I use a connection unit like this, would I simply wire both of the cut ends of the original circuit into the supply terminals?
What would the preferred approach be? What else should I consider?
