I'm looking to add a plug-on neutral combination AFCI/GFCI breaker for a new circuit. Can this be installed over the neutral bus if a different circuit already has a neutral screwed in to that part of the neutral bar, or do I need to move the existing neutral wires first?
1 Answer
The instructions for a Homeline plug-on neutral breaker indicate that the plug-on neutral clips land in the “empty” spaces on the neutral bar between the pairs of screws, so it should not be necessary to move any existing neutral/ground wires that are on the bars.
