1. Introduction
I have an Eaton CH Plug-On-Neutral Panel (CH42BPN200K).
I need a 20 AFCI/GFCI Breaker.
I found two or more part numbers that are for an Eaton CH 20 AFCI/GFCI breaker.
  1. CHFAFGF120PN (Eaton Catalog - City Electric Supply)
  2. CHFPAFGF120CS / CHFP120DF (Home Depot / Lowes)
There may be more part numbers that I just have not found yet.
(Note: I wish I could figure out how to make the following images smaller).
2. Questions
Are the following two parts the same or different even though they look almost identical?
Is one part better than the other?
3. CHFAFGF120PN - Eaton Catalog / City Electrical Supply
Eaton Brochure and catalogs show the part number as CHFAFGF120PN (Single-pole 10kAIC 20 Amps - AF/GF plug-on neutral). I went by the the local Electrical Supply House and purchase this:
Part Number - CHFAFGF120PN Part Number - CHFAFGF120PN
4. CHFPAFGF120CS - Home Depot / Lowes - $56.95
The Home Depot (and Lowes) appears to carry a CH Plug-On-Neutral breaker, but the part number is CHFPAFGF120CS (All-In-One Breaker). The part number on the device (CHFP120DF) is different than the part number on the box (CHFPAFGF120CS).
Part Number - CHFPAFGF120CS Part Number - CHFPAFGF120CS
5. Eaton Brochure
Plug-on neutral loadcenter brochure
6. Eaton Catalog
Eaton - Loadcenters and Circuit Beakers
7. Reference and Sources
Eaton - Plug-on neutral loadcenter http://www.eaton.com/ecm/groups/public/@pub/@electrical/documents/content/br00301006e.pdf
Eaton - Loadcenters and Circuit Breakers https://www.eaton.com/ecm/groups/public/@pub/@electrical/documents/content/vol01_tab01.pdf
    One catalog is dated 2014 and the other one is dated 2019. Commented Apr 29, 2020 at 6:39
  • I wouldn't get too concerned about model of breaker inside the box not matching the number on the retail package, they have to do something to differentiate the packaging. Sometimes when ordering light bulbs we could get a different availability options by adding BP (blister pack) to the part number. Different package, same bulb. Other suffixes would indicate 10 packs in little unmarked boxes. Commented Apr 29, 2020 at 14:38
  • Thank you for the comments. I tend to get a little too hung up. I am trying to attempt to get the most current and reliable product. Sometimes a newer model is better, sometime it is not. I assume that the Subject-Matter-Experts (SMEs) / Professionals in the trade / industry know early on or have a reliable vendor contact to find out more about a product. Commented Apr 29, 2020 at 15:40
Eaton - Catalog numbers still to come
I found this, not sure where though. The last page has "March 2019".
Example:
New plug-on neutral catalog number is:
  • CHFP120DF
Similar previous design catalog numbers:
  • CHFAFGF120PN
  • CHFAFG120
Now if I could only find these two AFCI Plug-On Neutral breakers:
  • CHFP115AF (AFCI 15 Amp)
  • CHFP120AF (AFCI 20 Amp)
  • Yeah, Eaton has been doing a lot of part number changing on the CH PoN gear (breakers and LCs) to make it fit the new system they're inaugurating with the introduction of the BR PoN product line Commented Apr 29, 2020 at 23:51
