I have two mailboxes: My primary home has a cluster mailbox with a standard CompX lock (it was replaced ~5 years ago, in case that's relevant), and my second home has a standalone mailbox that I own. I would like them both to use the same key. I know I can purchase a CompX lock online and it will probably fit in the keyhole for the Mail Boss mailbox, but is it also possible to rekey it to match my existing key? If so, is this something I can do myself or would I have to find a professional?
2It depends on locale. Some places consider the Post Office the owner of the mailbox, and you'd need to check on changes with them.– DrMoishe PippikCommented Dec 11, 2023 at 0:11
Since I installed the mailbox myself I don't think that will be an issue. This question is mainly about practicality, not legality.– Joey MarianerCommented Dec 11, 2023 at 1:01
3Have you looked closely at both of the mechanisms? It’s possible that they’re similar enough that you could buy two locks that are keyed alike for less than the cost of 1 plus a rekey.– Aloysius DefenestrateCommented Dec 11, 2023 at 1:25
It is possible to rekey lock barrels/mechanisms to use the same key if they are similar enough. You can call a locksmith to do it. However, the cheaper way is to remove both the locks and take them into a lock smith.
If that does not look too easy, then take both keys into a locksmith and they may be able to tell you with more certainty.
Take the key from one of the locks and see if you can slide it into the other lock. It will not turn but if the same key can slide into both of the locks a locksmith can rekey one of them. Then they will be KA - keyed alike - and then the same key will open both locks.
