I would like to mount a mailbox on the side of a column at my entryway. Every mount I have seen points the mailbox opening straight outward, away from the column center. However I would like my mailbox to be parallel to the column center.
Here is some ascii art to illustrate.
  • Symbol for the column: []
  • Symbol for the mailbox, with front/back at the ends: |
Standard mount, looking down from the top:
What I’m looking for, also looking down from the top:
Has anyone tried this before? Is there a set of hardware I can buy to achieve this?
EDIT
The column is plywood, with a slight taper reducing the width from ground toward ceiling.
The mailbox is a standard aluminum rounded-top mailbox.
EDIT 2
Pictures:
Current mailbox next to post New location to move mailbox Mailbox mounting details
    Will depend on the mailbox and column. I have a plain steel box mounted on top of a wood post. It would not be that hard to drill a few holes in the side and mount the way you want.
    Sep 17, 2023 at 14:32
    Some photos of your mailbox and your column would sure help your cause.
    – Huesmann
    Sep 17, 2023 at 18:12
  • @Huesmann thanks for suggestion; added pictures above Sep 24, 2023 at 15:22
  • Why not just screw it through the side, directly to the plywood side of the column? You'll need a stubby screwdriver, but easily doable.
    – Huesmann
    Sep 25, 2023 at 12:16
A couple of L brackets screwed to the plywood column and to a bit of wood fitted to the bottom of the mailbox will do this easily and without compromising the weather-tightness of the box.
Most "standard" round-top mailboxes have a recess on the bottom to take a mounting board, and holes to fasten into the mounting board. So you just mount the mounting board as a shelf, spaced far enough off the face of the column to permit the mailbox to fit, and any rain that gets between them to drain freely.
    Seems like the L bracket is pretty close. I could only find 90-degree brackets. Are there other types of brackets for other angles? I'm guessing my angle is 85 or 80 degrees - see picture above. Maybe I could just bend one to the angle I want. Sep 24, 2023 at 15:27
  • I ended up moving the whole mailbox, to the right side, and leaving it mounted on the existing posts. Had I gone with the side mounting, I would have used this approach, so I will mark this answer as accepted. Nov 1, 2023 at 15:22
Drill 2 holes in the side of the mailbox slightly slanted ( / ).
Screw through the inside of the mailbox into the column.
Use Fender washers and wood screws. I like Teks screws (Even though they are rated as metal screws.) I find they are great for this type of application and very easy to screw.
If needed use a fender washer or 2 between the mailbox and column on the upper screw, to adjust for the taper.
  • Thanks, I added details to post. Sep 17, 2023 at 14:44
