I was running the vacuum cleaner in my bed room this morning and suddenly the outlet went dead. I went to the power box and saw that all the circuit breakers were on. I then turned off the circuit breaker for my room and put it back in the on position. It appears to have solved the problem.
I am thinking that I over loaded the circuit but if that was the case, I would have expected the circuit breaker to be in the off position. It was in the on position. Do all circuit breakers move to the offset position when they shut off the circuit?
Assuming that this does not happen again, my plan is not to worry about it.
Note: I am in the United States of America
As it turned out, it did happen again. I called an electrician and he diagnosed the problem as a bad outlet. He then replaced the outlet. Now, I believe thew problem is solved.
