A couple of nights ago, I noticed that my bathroom exhaust had stopped working. It still makes a humming sound but it doesn't spin, so I assumed it's probably the motor.
I removed the motor/fan and then looked for a replacement online. The sticker with the model name has scratched off, although I can see from the cover that it's a Stelpro. Unfortunately, all the potential replacements I have seen connect to a standard power outlet, whereas the one I have has the below connector (Google tells me it's called a Tamiya connector).
Is it possible to buy a replacement, or would I need to replace the whole unit? If it's the latter, is that something that I would be able to do myself? For reference, my electrical experience is limited to installing a couple of dimmer switches.
