I have one of those integrated bathroom 3-in-1 ceiling units (light, heat and exhaust fan).
Recently the fan spontaneously stopped working. I took the unit down to inspect the fan motor and took it to an electrical service person to see if it could be mended, or if not to hopefully source a replacement. The techie pronounced the motor dead and confirmed my fears that replacement parts are not available from the manufacturer, one typically has to replace the whole 3-in-1 unit.
I despise the disposable mindset of modern consumer appliances so I went looking for another solution. I found A/C fridge evaporator fan motors were widely available and one 'universal' motor from an online retailer that remarkably had the same dimensions for the mounting posts and similar appearance to my busted one (albeit much lighter), so I thought I would try that.
Original dead motor: Original dead motor
My adapted replacement: My adapted replacement
The following specs are provided for the new motor:
240Volts AC, 10Watt, 50/60Hz. Shaft length 30mm, shaft diameter 3.17mm, total depth 90mm from tip of shaft to back of mounting knob.
Here are the terminals on the 3-in-1 unit (plastic fan shroud with lamp sockets) with the fan removed. The original motor had two writes running into the right-hand-side of the Fan and Neutral terminals.
Terminals
So I successfully fitted my new motor and connected the two wires to Fan and Neutral, but on hitting the switch, it didn't give so much as a twitch. I tried swapping the two wires (my understanding is for A/C motors this shouldn't make any difference) but it still didn't work.
My questions:
  1. This should've worked, right? An A/C motor is an A/C motor, so a straight swap like this should be okay?
  2. Have I killed my new motor? How does a motor like this (or particularly the original) die?
  3. What kind of tests can I do to confirm whether my motor is in working condition, or was DOA, or to isolate the source of the problem elsewhere? I've done some simple continuity tests of the connecting wires but I don't know what else I can test. (I should have tried wiring it to Light to rule out any issue with the supply-side wiring, but I didn't think of it...)
Thanks in advance.
Edit: The 3-in-1 is an Airflow Sunshine model 6600A, manufactured by Clipsal. Here's a picture. It's seen on page 5 of this brochure. Also on page 25 of this catalogue with technical data, although the unit depicted is slightly different to mine. I've contacted Clipsal and they've said they don't provide parts (and it's a discontinued model).
  • Who is the manufacturer of the device you are working on and show a picture?
    – d.george
    Apr 26, 2018 at 10:41
  • I added that information into the post. Apr 26, 2018 at 12:21
  • Sounds like you have a defective motor. What happens if you just fit the leads with a cord and plug and plug it in to a wall outlet?
    – Tyson
    Apr 26, 2018 at 13:23
  • @Tyson Thanks for the comment. I think on reflection it may be my manhandling has damaged it, there is an exposed copper thread that's become severed. I thought it inconsequential at the time but now I think it is part of the coil. I'll have to see if I can re-solder it together. Apr 26, 2018 at 22:31
An electric motor in definitely not not just an electric motor. They are very proprietary. It takes a lot of skill substitute one motor for anything but the OEM part number. There are tens of thousands of different kinds of motors out there. Almost none of them will substitute one for another. For example, with the motor you are working with, the stack of the iron laminations determines the torque the motor can deliver. The torque required is dictated by the size the design of the fan blade; the larger the blade the more torque required. I can clearly see that the motor you are trying to substitute will not provide the necessary torque to drive that blade, i.e. the original motor stack is so much thicker. This is just one of many variable that are in play. If you can clear the following list of variables you may be able to replace this motor successfully. #1 support/mounting criterion. #2 direction of rotation. #3 Torque. #4 RPM. #5 Shaft length. #6 shaft diameter. #7 Shaft configuration. #8 clearances. #9 Voltage requirements. #10 What environment was the motor designed to operate within.
Answer to question #2:If the motor still runs nicely it probably OK. These motors die because the bearing dry out. The lubrication last only lasts so long.
Answer to question #3. If you are getting proper voltage to the motor and the shaft doesn't turn the bearing are probably shot. With the lubrication gone you have metal on metal and it's only a mater of time.
  • 1/2 Thanks for the post! In regards to your points in answer to #1, I'm aware I'm probably not going to get the same performance as the OEM motor given the size/weight difference (I actually didn't realise till I received it that it's only half as thick). The question is more about why doesn't it at least spin up. The physical criteria actually seem pretty spot on, the mounting (with the adapted legs I made) and overall size fits in place quite nicely. The shaft diameter was smaller than the hole in the fan but I wrapped it and made it work. So should at least get the fan turning I thought. Apr 26, 2018 at 23:36
  • 2/2 To #2, that's what the tech I consulted thought too, that the bearing was dried out. I probably should have stated, he actually tried lubricating it for me and got it spinning freely but then when he applied power, the motor was lifeless. That's when the replace verdict was delivered. So I was wondering what else about the motor can fail and render it inert, since bearings aside I can't see much about it that can fail... Apr 26, 2018 at 23:45
  • Your gratitude seems heart felt. When the rotor locks up it stressed the winding. The amp draw spikes up. The wire these windings is made from is slightly heavier than human hair. This stress can simply open the winding. Additionally, when the bearings wear out rotor no longer spins in the center. The rotor can wear into the windings and open them. And just because you find continuity across the winding that doesn't mean you have a properly completely circuit. The winding can short across each other. Your welcome.
    – Paul Logan
    Apr 28, 2018 at 4:40
