I’ve got a situation trying to tile the surround of a tub. The biggest challenge occurs at the top edge of the surround’s wall, which is also the top of tub. At that location (see photos), the tub’s wall (above the surround and attached to the surround) slopes inward about 3/16-inch away from the back surface of the tile.
The photo is taking looking almost level along the top of the tub. The slope of wall (red) is shown sloping away from the plumb, yellow straight edge, which would be the back surface of the tile.
The top of tub is white, in the photo, the surround is red and immediately below the white. The black spot - seen between tub and yellow edge - is on the far wall (also red), at the end of the tub. The tile will come up from the floor (on right, not shown) and stop at or below the top of tub.
The question is how to finish what will be the top edge of the tile (once attached to the tub) and the space between tile and tub? I’ve considered
(1) sloping the top few inches of the tile to match the tub’s slope; but ruled this out because it causes too much lippage at the joints below;
(2) bring the tile up straight and either (a) fill the space behind with caulk, or (b) add edge trim to fill the gap: for this option (b), I’ve considered several different trims, including:
(i) edging, e.g., Schluter’s (or TrimMaster’s) L-, T-, R-, and RS- shapes (even some stair nosings)
(ii) aluminum and Flexstone L-caps
(iii) ceramic V-caps
(iv) pencil trim
and (v) something else?
I’m thinking the best option is to just fill the space with caulk, or put in two L-shaped edging profiles (not the L-caps, nor stair nosing) back-to-back.
I’m all ears. But please it’s too late to say "shoulda done this or that," and suggest starting over with the surround, that is just not a viable option at this point. so please concentrate on a solution of the situation given.
