I would like to fill and cap the last few inches (is there a standard how deep?) between this r6" ound chimney liner and the bricks around it. I was planning to make a base with plywood that matches the currently empty space between, essentially a square with a 6.5" hole (leave 1/4" spacing) in the middle, suspend it a few inches below the top on 4 pieces of wire from two pieces of rebar sitting across the top of the chimney, them pour concrete on top.
Since the plywood base would be permanently trapped inside, my question is is plywood the correct material considering the general fire hazard of a chimney?
