Planning on installing a wood burning insert in exsisting fireplace, the top of the flue at the chimney is spalling and was wondering if/options of repairing? the wood burning insert will use a stainless liner and its cap will be sealed to the top of the existing clay flue. Pictures included:
In my area a liner is required for a wood or pellet stove even if the flu is serviceable. I would have the cap made to protect what is left and the new liner will reduce any heat damage to those areas by being centered in the flu. Make sure to use solid or double wall if required, never use the flex pipe (looks like heavy dryer vent). that stuff really traps the creosote and there is no real way to clean it a standard brush just pokes them full of holes. I have heard stores in my area state that the flex line is legal but it is not here so even if the store offers flex at a couple of hundred dollars savings don’t use it unless you want a chimney fire.
Flex is so inexpensive relative to rigid, I think it's meant to be disposable. – AdamO Mar 18 at 19:43
