I'm trying to install a smart thermostat in my home. It has only an external air conditioner (model P3RD-042K, here's the manual/wiring diagrams), no heat. The current thermostat has an unused blue wire running to it, but on the air conditioner side it's not to connected to anything. I looked around, couldn't find a c terminal to connect it to. There aren't any terminals at all, just a mess of wires from different parts of the unit. I've included a picture of the wiring. Is there somewhere I can hook up the blue wire? Thanks!
And here's a closeup of the transformer label: Edit: After looking at the image, I suspect that 'COM' is for common. Is that correct?
