I just got the sacrificial anode rod to my hot water tank replaced (rod is shared with outgoing hot pipe). I told the plumber to make any changes necessary to make this task easy the next time (replace non functioning stop valves, more robust fittings, union). He didn't recommend the union, so I went with his judgement. He replaced all the piping to/from the tank and around the new stop valves. However, he used press fit fittings instead of sweated copper. Before I call to complain it is now harder to remove the anode rod, I need to know how you remove these fittings. I've only found one website that mentions this and it said to cut the pipe around the fitting. That can't be true--the pipe would now be too short to insert a new fitting.
How do you do it? Please note, these are PRESS fit types that need a crimper (ProPress, for example), not the push fit (sharkbite, for example). See picture below:
UPDATE: I now realize I wasn't clear about who would be removing this in the future. Thus, there could be two different answers: one for a diy and one for a professional plumber. I'm mostly interested in how a pro would to it, but I think for everyone's knowledge, a diy answer would be good information as well.
UPDATE: I just got done measuring things and to be fair, I think a plumber can cut a section of pipe and solder in a repair coupling (not press fit, thank you) so removing the anode won't entail cutting out the press fit fittings. You have to be careful how close to the fitting you solder because of the o ring. The distance is vendor specific. Viega ProPress is 3 tubing diameters which would make it easy in my application. However, the plumber used Nibco and they want 12 inches which is too far. But Nibco says if you can't meet the 12 inches, use a wet rag to keep the fitting cool. Not ideal, but for now, I'm calling it good enough.
