So in my room I have this safe I want to remove it because it's in an inconvenient spot and rather have it in another room. I have these bolts inside of the safe that are in my wall and the problem is, I can't get it out. There is nothing I can do to remove it and I don't know if there is anything else on the other side of the wall that could damage the wall when I remove it. Anybody got tips or answers on how I can remove it?
  • Is the picture of the inside safe wall? Why can't you remove the nut and pull the safe off the bolt?
    – jay613
    Commented Feb 4, 2023 at 23:13
    "There is nothing I can do to remove it" Can you explain what you tried and why it didn't work? Commented Feb 4, 2023 at 23:54
After adjusting the exposure on your picture, I suggest you buy a wrench, if "there's nothing you can do to remove it" (and you actually own it, as opposed to it being part of a rented/leased property. Which "my room" as opposed to "my house" calls into question...)
Exposeure adjusted
  • I thought it was just a simple lock nut at first, but zooming in there seems to be a separate lock ring(?) on the nut. Might just be my eyes.
    Commented Feb 4, 2023 at 22:33
  • It's a terrible picture. We'd need a better picture to have any idea if it's more complicated than "lefty loosey" which is what it looks like to me from what I can actually see in that terrible picture. Could just be a nylock nut, and these do lefty loosey just fine..
    Commented Feb 4, 2023 at 22:36
    Guess a simple wrench would be okay, but a cutting torch or angle grinder is more fun.
    Commented Feb 4, 2023 at 23:11
    @crip659 Fine, let's use the oxygen lance on it. en.wikipedia.org/wiki/Thermal_lance Pretty sure a sledgehammer will do the job, too. Ah, ya know what, it's a safe. Let's do it the old school traditional way with nitroglycerin.
    Commented Feb 4, 2023 at 23:21
Assuming the bolts are only into one plane (wall or floor) you would open the safe, unscrew the nuts, remove the safe from the wall, then deal with the bolts or "studs". The latter would be screwed into the wall and you would unscrew them with a pipe wrench or with pliers.
There is probably a section of the stud next to the wall where there are no threads or the threads are not used. The best pliers would be locking pliers like Vise-Grips. Maybe channel locks would work.
If the studs would be special design with have wrenching flats exposed when the safe was removed, then a regular wrench could be used.
    You could use a die grinder with the appropriate blade and cut it off.
    – Gil
    Commented Feb 5, 2023 at 1:00
