It appears that you want to make cuts length-wise through a board, and that the drawing is showing the end-grain, not a top-down view. I think that confused many people.
The easiest way to get these cuts at a consistent angle is to make a pair of saw guides and clamp them to the top of the piece of wood being sawn.
Using a piece of 1x4 (or similar), make a cross-cut at the angle you're after. This way, you only have to hold the proper angle as you cut down through a 3/4" thick board, and only for the 3-1/2" of the width of the board. If your angle happens to be 45°, you could stand the piece on edge in a standard miter box and cut with the 3/4" edge up and have a pre-cut guide for this first block. Cut so that the off-cut piece is at least 3" long.
Once you've got an angle on this piece, rip it length-wise to have 2 pieces, each ~3" long, about 1-1/2" wide, and with one end cut at your desired angle.
Set one guide block so the bevel is resting at the cut line on your target board, and clamp it firmly in place. Rest your saw against this block and start sawing.
Before the saw clears this first guide block, stop with the saw still in the kerf and set the next guide block against the edge of the saw, further along on the target board. Clamp this firmly in place.
Continue sawing, leap frogging the guide blocks down the length of the board so you've always got a guide block to lean against, setting each against the blade of the saw as a reference to ensure you're still on the same cut line.
With a half-decent back-saw (that often comes with a miter box), the blade will be thick enough (and the fold on the non-cutting side stiff enough) to ensure you're making a straight cut and that the future guide blocks end up in the right spots.
The hard part of cutting the arbitrary angle is now reduced to one cut to make the guide blocks, and that can be reasonably easily done by marking the angle on the 3/4" edge of the 1x4, then, using a square, "wrap" the line along the 3-1/2" faces of the board. This will make maintaining the proper angle reasonably easy by taking your time to cut, making sure that you're sawing through the line on both faces.
