I have an existing 15 amp hot-water recirculation pump that's powered by a 3-way switched receptacle. Toggling one of the two 3-way switches either turns on or off the pump.
My goal is to be able to replace each of the two 3-way switches with momentary toggle switches that would cause the pump to turn on for fixed amount of time (say, 2 minutes) and then power off automatically.
- Is it possible to repurpose the existing 3-way wiring for this purpose?
- What kind of timer is required at the pump end of the circuit?
