Goal: Add several waffle ceiling lights to a room.
Idea: I want to use the existing 3 way switches in that part of the house to control the lights. This makes sense in my mind since the switches are already there and the wiring is already in place.
Concern: The 3 way switches go to a an outlet. I am uncertain on the know how and safety of tying into that switch to control the lights because I would like to replace one to be a dimmer switch. Something about having an outlet on a dimmer sounds sketchy.
Question. What’s the best way to utilize those existing 3 way switches to power/ control the new lights and convert the outlet to a normal one?
Here is layout of the outlet I want to convert to always hot. It is currently always hard on the bottom and the top is the one that is switched. Is it possible from what you see? It’s the outlet labeled “A”. I made this illustration and the wires are either coming in from the right or the left based on how I observed them inside the outlet box. The outlet on the right is NOT switched. I believe it only carries power from it to the next one.- I attempted to disconnect the two travelers cables from outlet A and just cap them. Leaving the black hot and the white going but then I got some open hot/ ground error. Any thoughts or ideas. I figured this would be the first step in the bigger project – converting this outlet and freeing up the two travelers to use for the lights eventually. Any help is greatly appreciated my electrician canceled on me who was going to be my advisor on this. Thanks!
