At a short term rental property. The stovetop is locked. I don’t know how to unlock it and am not even sure I can read the stylized brand name
    Landlord should know, they are responsible for maintenance, or have a reason.
    Commented May 5, 2022 at 16:57
    just in case, try a press-and-hold on the lock button, or on the power button.
    – GOATNine
    Commented May 5, 2022 at 17:20
    I’m voting to close this question because appliance operation is off topic.
    Commented May 5, 2022 at 18:19
    Just googled why a stove would have a lock on it. Seems to be for a child safety feature that you need a child to open. Do not know how we all survived without this. We only needed to touch a hot stove once.
    Commented May 5, 2022 at 18:30
    It also says "Induction", so unless those things they put on the stove before accidentally turning it on are metal, there won't be a problem. You can put your bare hand on an induction burner turned all the way up and so long as you don't have metal rings on, you won't feel the slightest bit of heat.
    Commented May 5, 2022 at 21:48
(1) Lock: Touch [lock] key more than 4 seconds, [lock] icon shows in LED, it is locked, there is no function to touch any other keys.
(2) Unlock: Touch [lock] key more than 4 seconds again, [lock] icon doesn't show, then it is unlocked. Maybe touch more than 4 seconds to turn off all functions
Empava Manual
