I bought a Hunter universal remote set to replace the ceiling fan/light remote.
The old receiver has "to Motor L" and to "Motor N" while the new one only has one wire for the fan.
Is there a way to make it work?
old receiver
Click images to embiggen
hunter receiver
The one "To motor" is the speed-controlled live. It replaces "To motor L"
The other motor lead previously served by "To motor N" goes to the regular neutral wire.
  • Thank you for your answer. Just to clarify, so I should connect the "Fan" to the "Motor L" and the other motor lead to the white wire beside the black live wire? Thanks Commented Jan 28, 2022 at 18:34
  • I already installed as instructed and works like a charm. Thank you! Commented Feb 8, 2022 at 21:06
  • yeah the fan is the bit that moves the air the motor is the bit that moves the fan, and the electricity is the bit that moves the motor :)
    – Jasen
    Commented Feb 8, 2022 at 21:21
