I am trying to replace a busted Hunter ceiling fan remote. The receiver unit from the old remote had 5 wires - live and neutral, and then 1 that was labeled "fan out", 1 that was labeled "light out", and 1 that was labeled "common out."
The fan unit has 4 wires - 1 green wire that is capped, 1 blue wire labelled "for light", 1 black wire, and 1 white wire.
Can I use the new remote/receiver that I have and ignore the white wire (obviously capping it for safety?
Or do I need to replace the new remote receiver unit with a different one that has the third "common out" wire?
I only have a single light switch in the room.
