Any ideas on how to get this MOEN M0036 cartridge out? I've tried to do but only have damaged edges so far. Thanks in advance.
After adjustments with file, it did not hold support as it made from copper and cover is thin
Update: Is it possible to use reverse drill bit and extractor to help with that?
If you have a file for metal, you might try straightening those edges and using a socket. Otherwise a 12" pipe wrench is your best bet
