My sump pump discharge is located ~6" above grade and the drain line is on the surface (i.e. not buried). I'd like to create an air gap so that the water has somewhere to go if the drain line freezes. Typically a component like the one below is used to create this air gap. These are great, however all the ones I can find are 5-6" in heigh which doesn't leave enough space to connect the drain line.
![](https://i.sstatic.net/Nz4ha.jpg)
I'd like to create my own air gap but I'm not entirely sure what the best way to do this is. The diagram below explains what I'm thinking, with example parts afterwards.
"Bullet" basin: Atrium grate:
I can sink the bottom of the basin into the ground a bit, and cut the atrium to size. Does this make sense, or am I missing something here?
