They just installed granite countertops with deep sinks. Now if I reconnect everything together the drain pipe from the wall is too high. Short of cutting open the wall and lowering the drain pipe (or doing away with the disposal) is there anything I can do? I checked and the pipe in the wall goes straight to the left, so there would be extensive destruction to move the wall pipe.
So would either of these work?:
- Use and elbow and extend the wall pipe to the p-trap?
- redirect the disposal directly into wall pipe (placing drain after p-trap)?
The distance from the wall pipe center to the top of the p trap is about 4.5”
