I have two concrete walls on either side of a proposed deck area. In the middle of the span I have some concrete columns that will support a beam for a deck. My proposed deck design has 2x12s sitting on the concrete walls and attached with 2x12 joists to the center beam that rests on the columns. The height of the walls is ~6" lower than the columns.
How should I build up the concrete wall to support the 2x12s at the same height as the center columns?
If it was 1.5" lower than the columns then I would put down a sill gasket, epoxy in some anchor bolts and put a plate down and have 2x12s sit on it. With it 6" lower I have to build up 5.5 inches.
Ideas?
Maybe I put down a plate, anchor bolt it, add two 2x members cut to 4" high, top it with another plate to make a box for the 2x12s to sit on and have the anchor bolt high enough that I bolt the top of the box to the concrete.
Concrete walls are level and flat. I'll plan for a 2% slope from the top of the plan view to the bottom - away from the house. This deck is self supported and does not tie into the house.
Attached a sketch of the plan view of the structure. Ignore the first level deck
deck structure plan view
_______________________________________________________________________
      6" gap                   |  |  |
      ______                   |  |  |                       ______
     |      | <-- concrete     |  |  |<-- 2x12 beam         |      |
     |      |     wall         |  |  |                      |      |
     |      |                  |__|__|                      |      |
  • Is the concrete wall level and flat, or does it require some leveling work? And are you hoping to keep an open sight line over the concrete walls?
    Mar 15, 2021 at 18:24
  • no open sight line over concrete. I'll add a metal drip to the deck surface that hides the wood to concrete. deck surface gets torch on membrane. Mar 15, 2021 at 18:48
Your final suggestion is probably the simplest, but you don't need to run anchor bolts all the way from the top of the sleeper beam. You also don't need a top plate. Just bold down the plate, then fasten the other two beam components to it.
   _|__|__|_
  |_________|
If you'd rater keep the space over the beam open for airflow or light or whatever, you can probably find an elevated post/beam support that will reach that far and not break the bank. Then you could put in a flush beam, like the one at the center of your current plan.
 ___||__|__||______________
   ____||___
  |_________|
You'd need to install supports at intervals that suit the beam size and load.
