In my flat I have a spur from the ring main to two double plug sockets either side of the bed. There is a 13amp fused spur switch between the ring main and the spur. I want to extend the spur to go to 2 wall lamps (they have a on/off switch in the base).
Do I need another fused spur switch between the end socket and the wall lamps? If so why? Thanks!
