I have been trying to replace this spotlight without success. I could not figure out a way to remove it . Any ideas?enter image description here
    You might list the things you have already tried - the most obvious thing I would say is unscrew the bulb but surely you tried that already?
    – izzy
    Jan 13, 2021 at 16:46
  • Did you try pulling it straight down???
    – JACK
    Jan 13, 2021 at 16:48
    Please get a sharp, well-lit photo. I can't see any detail in that one.
    Jan 13, 2021 at 16:49
    Are you trying to replace the entire fixture (based on the condition of the paint on the trim ring, that's entirely reasonable), or just the bulb?
    Jan 13, 2021 at 17:27
  • pull the whole fixture straight down. i know it's scary the first time... it might be stuck, but it's spring loaded and made to be pulled out.
    – dandavis
    Jan 13, 2021 at 20:06
if a GU16 bulb, then you have to push -in- and turn. This is due to the little 'nubs' on the end of the connectors
