This light fixture came with my new house. Cannot find the manual anywhere for it. 5 of the 6 bulbs went out within a few days of each other - likely reached end of life together. But one lives on. These look like MR16s but I’m not sure.
The bulb with the reflector can change position, looks like on a gimbal.
The outer ring around each bulb does rotate, but I have not been able to pull it out. I’m not sure what’s the best way to do that.
Any idea how I could change these 5 bulbs without having to open the frame? And if I could replace them with LEDs?
Sep 8 update:
Thank you all for the answers so far. Took a costco card, put it in the ring of the fixture, and was able to gently pry it out. They are pretty tight fit though! I'm wondering if there is a way to make them come out easily, but I don't see a twist mechanism or something like it. I have taken out two fixtures so far. Added a few more pics. Any ideas??
Bulb info: 44865 12v 35w 36degrees 430lm 2900k GERMANY OSRAM
Glass globe casualties: 1 so far. They are so close, that it's impossible to not have them bump into each other. One cracked in the air, fell off, and shattered all over the dining table.
