I'm running a 15 amp circuit to a small shed using underground 3/4" PVC conduit. I'm using an LB box to enter the side of the shed as shown in the picture below. The female end LB box protrudes about half an inch into the shed. The wall is only half inch OSB plus a very thin panel veneer.
I want to turn the conduit up and into a disconnect. I was planning on using a junction box with the LB came through, but I suppose I could just use conduit to go all the way to the disconnect.
What would be the best way to do this?
  • What style of disconnect device are you using here? A pullout switch (A/C disconnect), a safety switch (with the handle on the side), a main breaker in a loadcenter (breaker panel), or a simple snap switch (light switch) since this is a single 15A circuit we're talking about here? Commented Sep 6, 2020 at 18:29
  • It's a pull out (AC) disconnect. I'm not sure if it's even required, but I figured it would be good to have since the breaker is not conveniently located. I was planning on mounting that a few feet above where the conduit comes through the wall. I just need to make the transition through the wall and probably from pvc to metal.
    – Inquisitor
    Commented Sep 6, 2020 at 19:37
  • Were you planning on finishing the inside of the shed? Commented Sep 6, 2020 at 19:47
  • No. I just want to mount the conduit/junction box/disconnect directly to the OSB... Shimming if necessary.
    – Inquisitor
    Commented Sep 6, 2020 at 20:40
  • Is there a particular reason you want this disconnect to be indoors, by the way? Commented Sep 6, 2020 at 21:00
I completed the project and all is well.
  1. I added some 2x4 blocking to provide a bit more depth to work with.
  2. I solvent welded a small piece of 3/4" conduit between the female end of the LB coming through the wall sheathing and a threaded terminal adapter (the small piece of conduit is completely embedded in the fittings and not visible).
  3. I then spun on a metal junction box on the terminal adapter until snug against the blocking
  4. I ran 3/4" conduit from the junction box up to the disconnect.
  5. The load side of the disconnect is 14/2 Romex.
  • Good overall. One thing though: does the ground wire make a pitstop at the metal box before continuing on to the disconnect? Commented Sep 10, 2020 at 0:29
  • It does not. Does it need to?
    – Inquisitor
    Commented Sep 10, 2020 at 11:25
    Yes, since its a metal box, it needs to be grounded. Commented Sep 10, 2020 at 11:36
  • Thanks. I overlooked that. I will ground the box. Can I strip the insulation without cutting the wire and screw it to the box?
    – Inquisitor
    Commented Sep 10, 2020 at 13:19
  • The "strip and screw" for an onwards ground is something I'm not sure about, myself Commented Sep 10, 2020 at 23:13
