I am adding an outlet in my unfinished basement from a cable that will run from the ceiling down a corner of the room. I was going to just attach the cable to the studs but I would like to protect the wire due to the location.
I've read that I should not run the cable through conduit, but was wondering if there's a way I can use the same cable, but take the sheathing off when it's just inside the conduit (and use some type of clamp). That way I don't have to use a junction box where the wire meets the conduit and I still am not having the heat issue of cable through conduit.
I was planning on using PVC conduit and outlet rated for outdoors since it's in the basement where it gets cold in the winter.
Thank you!
