I bought an extractor fan from homebase. One of these: https://www.homebase.co.uk/humidity-controlled-extractor-fan_p594561 . I didn't get very far with fitting it though because step one is "Remove the front cover" but this is proving very difficult.
I have made a little video of me explaining the problem (with a bit of help from a 3 year old!)
On the top edge there is a clip which pops open with a screwdriver, and it start's coming open (I can pull it apart about 4 millimetres and start to see inside from the top), but at the bottom edge of the fan there is no clip, and the front cover does not want to come off at all. I can just about prise it apart by about a millimetre. I can push a knife blade in there along the whole bottom edge (see following photo), but something in the middle near the bottom (by the red light) is holding the front cover on tight.
There are various holes which look to be mostly for the screws which will hold it to the wall (from the direction of inside-out, meaning I need to get inside of course). Near the middle there's an interesting looking screwdriver-sized hole you can see in the photo, but solid edges all around. No clips or moving parts to poke at. I can't see any other clips or screws, but I feel like I must be missing something. I could just pull harder, but it feels like I'm at the limit before plastic starts snapping.
Oh I almost forgot the funniest part. The instructions have a sentence explaining how to do it! But it seems to be badly translated or something. Here it is word for word:
"Remove the front cover. To remove the front cover, first remove the hole plug than using screw driver to remove the self tapping screw, then cover can be remove unclip"
It's strange because the rest of the manual is well written. Just that one sentence... which is the sentence I need! Where is this "hole plug" / "self tapping screw"??
Maybe I could find out more from a manufacturer, but it's just generically homebase branded. "Homebase Extractor Fan. Humidity Control Model". There is a sticker on the fan itself with the numbers "SPA255 B141319"
